Results 1 to 9 of 9
Thread: Torque Management causing Rough Idle in Drive?
    Feb 2018
    4
    Hi guys,
    I'm running into an issue with my idle tuning. This is on a 2000 Chev Silverado 1500 5.3L with P01 ECU, has a turbo and a moderate cam. I'm running the Enhanced 3 Bar OS if it matters.
    I can get the truck to idle fine in Park, Reverse and Neutral. When I put it into drive though, the ECU pulls a bunch of timing causing the truck to idle rough and drop a bunch of RPM. To compensate the Desired Idle Airflow ramps up to its max to try and bring the RPM back up.
    I have figured out that it is the torque management that is causing the ECU to pull the timing. If I zero out the torque management table, the truck idles fine in drive, but I'm concerned that it will damage the transmission since the torque management won't be pulling any timing during the shifts.
    Is there a way I can disable torque management at idle but still have it active during shifts?
    I've made a video to illustrate the problem here: https://youtu.be/mtFgbxQXFug
    Let me know if there's a way around this.
    Randy
    Sep 2017
    736
    Quote Originally Posted by rengler View Post
    Hi guys,
    Randy
    In system optione under the systems tab does Brake TqMgt have a 1 next to it? If so try 0 and see what happens.
    Then i believe you have to do a "write entire".
    Dec 2011
    San Antonio, TX
    319
    Post your tune file and logs
    JTC Performance - Authorized HP Tuners Reseller
    Remote performance tuning
    Feb 2018
    4
    Quote Originally Posted by anniversaryss View Post
    This fixed it as you probably saw in the facebook group, thanks for your help!!
    Sep 2017
    736
    Awesome good to know. I see this all the time or I wouldn't have known
    Oct 2009
    13
    I know this is a few years old, but I just put a 408 in my 2003 Silverado and I spent hours chasing my tail trying to figure out why it was pulling 25+ degrees of timing, kicking out of closed loop, and stalling when stopped in gear. Such a simple fix to an annoying issue.
    I just wanted to say Thanks!!!
    Sep 2017
    736
    Quote Originally Posted by ViaBellator View Post
    Good to hear
    Mar 2022
    I just looked at every gen 3 file I have and it looks like brake tqmgt under system options is a 1 on every 4l60e application and a 0 on every 4l80e application.
    7,648
    Quote Originally Posted by toflaherty View Post
    2002 Silverado 1GCGC13U22F236000 LQ4 4L80E (OS 12212156).hpt
