I just got my LC-1 back from being repaired. Hooked it up, turned it on without the O2 sensor plugged in. Key off, plug in sensor, key on, blink blink... It does this for 2 minutes. I'm like WTF. I finally turn it off and start thinking.
If you hook the LC-1 up per Sound Engineers diagram, the LC-1 Analog ground is not there for it if the HPT MPVI Pro is not plugged into the DTC connector. Once I plugged it in, the LC-1 finished the warmup and calibration immediately. Maybe its because the O2 sensor is hanging in mid air and not grounded? I seriously think it has to do with the DTC connector. Just to make sure I have it hooked up right.
Red - +12 switched on the key
Blue - Grounded to the block
White, green, and black are all tied together and grounded to Pin 5 on the MPVI. The LED is spliced inline between pin 5 and the black coming from the LC-1. The button is splice on either side of the led. (maybe this is where I'm wrong?)
Yellow - not hooked up
Brown - Pin 1 on the MPVI
So to reiterate, the MPVI only has something connected on pin 1 and 5.
Is that right? If that's correct, then the LC-1 analog ground is not connected unless the MPVI is plugged into the DTC.
