2001 C5 with a Carroll Supercharger kit, just a basic non-intercooled Vortech V2, guessing it will make 5-7 psi tops. Bought the car with the supercharger not installed and an NA tune on it, but we know the car was run previously on the stock MAP and 5-wire MAF. We tuned it on a stock OS, VE tuned without touching boost, and then pulled the limiter from 6750 down to 6200 just to stay under 12,000 Hz on the stock MAF. Car ran pretty well.
Today we installed an LS7 MAF with an IAT breakout located after the supercharger and a 2 bar MAP sensor. We applied the 2-bar OS and prepared for VE tuning with the MAF disabled and unplugged, populated the VE table, but couldn't go much past atmospheric- we got a couple hits at 110 kPa, but otherwise it wouldn't make any more power than that. Re-enabled the MAF and plugged it back in to try MAF tuning with a guesstimated VE table, same issue. We even tried an otherwise stock 2-bar tune with guesstimated VE table and no other changes like disabling DFCO and ran into the same issue.
I'm confident it's something in the tune, I'm sure it was making boost on the stock OS because we were maxing out the stock MAP sensor. But now with the 2-bar OS, 2-bar MAP sensor, LS7 MAF, and IAT breakout, it won't make boost anymore. Any direction would be appreciated.
