So haven?t touched my tcm since the initial changes I made when got it back from hpt from getting locked up. I made some changes and wrote it and been fine so don?t usually mess with it. Wanting to raise my shift points I go to do a new write and won?t take. So I try to read it again and says it needs to be sent for unlock service which has been done. So contact support and all I?m told is I licensed it on the mpvi1 on this license and now using a mpvi2 and that?s it. So I assumed they fixed it on that end but still not working. I did upgrade to the mpvi2 by trading in my old 1 as they recommend. Had they told me it was going to screw with my unlock I would have kept the old one and not sent it back. Really hoping this is an easy fix and don?t have to send back the tcm. It doesn?t make sense if your a shop and do this you have to send back say 20 tcm you have licensed and unlocked? So that doesn?t even sound like they would expect that and if did they would warn you before the upgrade.
Trying to go to the track today and support takes forever to get back so hoping someone here can point me in the right direction.
