Vehicle:
2003 Ram 1500 shortbed
L33 SBE
sloppy stage 1, yes 1
pac1218 springs, stock pushrods
Decapped Flex injectors
Stock ported fuel reg, 58psi base pressure
T4 Log manifold with crossover
VSR Billet 7875
VSR 44mm wastegate
Pump 93 from a "good" source
Poly engine and transmission mounts
IFR and VE scaled to get 210kpa (14.7psi) with 1.20 g/cyl for adjusting timing. Truck completely falls on it's face with the retard, I don't "hear" any knock and AFR's are very conservative, I have done a few different pulls at various afrs and timing changes but I still seem to get knock. I have messed with some of the knock settings so please take a look. I pulled 5% out of global and still get retard. It looks like false knock to me but I would like a second or third opinion. I haven't made det cans yet but will in the future. I should be around 11 degrees of timing with 14 psi of boost which is fairly conservative from what I have read.
Thank you in advance!
