Results 1 to 3 of 3
Thread: Speed Density ReWrite Blank Tables
    I rewrote the OS to add in the Speed density tables so I can tune my truck easier then the Main VE Reversion setup (I'm new to tuning). However the rewrite has all the Main VE tables blank and multipliers set to 1. Is there a base VE table I can copy and paste to start working off of? The truck starts and dies after the rpms jump to 1200 assuming its because these tables are zeroed and Cranking VE is 100 across.
    I have the E38, GM Gen4 V8 5.3
    TMR3 AND TTMR Plus SD rewrite.hpt
    13,569
    Make sure the MAP data didn't change on you either, if you are still running a stock 1 bar MAP.
    You have to take the VVE data and use excel to copy/paste that in there, flip the axis and paste the data back in the new VE tables. VVE to VE has the axis flipped so using excel is needed.
    Feb 2015
    Perth, Australia
    974
    if you haven't changed the map sensor you'll need to enter your stock scaling.
    either 94.43/10.34 or 128.13/-0.31
    and you'll need to populate all 3 VE tables.
    copy the data from the VE tables ONLY in attached file as starting point.
