Results 1 to 20 of 25
Thread: Insufficient Fuel Flow 2019 mustang GT
    Advanced Tuner silverbullet08's Avatar
    Dec 2009
    Houston, TX
    453
    Is there a patch available or any tricks around this? Im getting "insufficient Fuel flow" limitation at 6200-6300rpm or when achieving over 10lb/hr fuel flow and it shuts throttle. Tried rescaling some of the fuel tables to read higher but not getting any where. Seemed to start after rescaling MAF to read beyond factory scale. I have seen the patches available for 2018 and earlier cars but don't see anything on this operating system? I Tried emailing support on this Sunday but still haven't gotten any response back.
    Car has appropriate fuel system upgrades and is no where near maxing injectors or pump.
    HP-Unlimited Tuning and Custom Fabrication
    Houston area performance parts dealer
    MD800 Mustang Dyno 713-560-3889 Taylor
    2016 Camaro A8 "shop car" FIRST 6th GEN CAMARO OVER 200mph IN THE MILE 203.5mph
    Jul 2017
    529
    Is this forced induction? IIRC, that comes from maxxing out the maf sensor. Need a larger maf tube.
    Apr 2018
    605
    Quote Originally Posted by silverbullet08 View Post
    That's pretty bad for a stock car. I guess I'll keep my 14
    Dec 2009
    Houston, TX
    453
    Quote Originally Posted by MRRPMBRP View Post
    It is procharged. MAF is relocated to the passenger end tank of the intercooler with the kit. Piping is all 3" so if that's the case then its going to take some fab work to get these procharged mustangs making decent power. Any other thoughts?
    Dec 2009
    Houston, TX
    453
    Quote Originally Posted by blackbolt22 View Post
    Its not far from stock with just a D1X and headers with cats.. Over doubled power to the tire from the base 424hp run. I figured it wouldn't be that easy with out some type of quirk.
    Oct 2016
    Poland
    1,744
    Hmmm post a tune if you wan't any help. There could be a number of reasons.
    P.S.
    Not the best location for MAF.
    Nov 2009
    All Around
    3,149
    dont like their locations at all.
    Jul 2017
    529
    We did a 2018 Mustang, Procharged, worked fine up until almost 800rwhp, all stock Procharger kit. We tuned from the Procharger tune using HPT.
    What power level are you at currently?
    Dec 2009
    Houston, TX
    453
    It's making 860+rwhp with the throttle closure. Agreeing with all above the maf location is probably the issue. Thanks. Same type of issue we had with our 6th gen camaro when it started reaching these power levels.
    28,268
    Are you running the stock fuel system?
    What injectors are you running?
    Any dtc's?
    MAF location hasn't changed for them in years ie its been in the drivers side of the IC for a long time so I'm not convinced thats the issue. Nor is the power level as I've seen several 18's making over 900rwhp in procharged applications.
    Feb 2019
    info on the fuel system Bill @HP
    FORE INNOVATIONS FUEL SYSTEM LEVEL 2 DUAL PUMP (2018+ MUSTANG GT/GT350) 42-822
    Fore Level 2 Dual Pump 2018+ Mustang
    Intake Manifold:OEM
    Power Adder(s):Procharger
    Primary Fuel Pump:TI Auto F90000274
    Secondary Fuel Pump(s):TI Auto F90000274
    Electrical Upgrade:FC3 Staged Controller with 4 gauge wiring
    Fuel Lines:PTFE -8 Feed / Return
    Filter Media:Stainless Steel
    Filter Length:Upgrade to 128mm Filter
    Mechanical Gauge:0-100 psi Fuel Pressure Gauge
    Pressure Switch:Honeywell Pressure Switch for FC3
    Flex Fuel Sensor:Flex fuel sensor intercept fittings
    Boost / Vac Lines:Boost / Vacuum Manifold Kit
    Sep 2010
    872
    Quote Originally Posted by tedkubiak23 View Post
    Intake Manifold:OEM
    That is definitely enough fuel system for the set up. I've seen the insufficient fuel flow source on a few cars iv'e done, always starts around 6500rpm, I only see it on s550's for some reason, never seen it on a s197. So far I mostly run into it when tuning manual cars, I haven't had a auto with this issue yet.
    Oct 2016
    Poland
    1,744
    Usually DD changes trigger that limit from what I can tell.
    Do you have a read of the procharger tune before you modified it?
    Dec 2009
    Houston, TX
    453
    Quote Originally Posted by BoostedYote View Post
    No procharger tune supplied with the kit. "tuner kit"
    Dec 2009
    Houston, TX
    453
    Any dtc's?
    As stated earlier its has the fuel system to support the power and more, Twin 450lph pumps and id1050x injectors with regulators and-8 PTFE feed line with return.
    It doesn't throw any codes even after a few key cycles and triggering it multiple times. Maf location is in the passenger side tank "outlet of intercooler" on this kit.
    Jul 2017
    529
    Curious why you put such a nice fuel setup on the car?
    The '18 we did had only a BAP, 60%dc at almost 800rwhp.
    On your maf meter, simply put it in a larger tube & retune. If it's in a 3", flare to 4" & taper back down to 3", or run 4" all the way to tb.
    Dec 2009
    Houston, TX
    453
    We are trying that idea out right now.
    We had just a BAP and fuel pressure dropped to 20psi by redline at 730hp on our dyno maintaining .80 lambda.
    Jul 2017
    529
    Did you tune the fuel pressure voltage?
    Dec 2017
    767
    Mine originally tune that was done for me before I started to learn on my own all the dd tables were bumped up quite a bit, I’ve seen several tunes where they were all left alone. What’s the proper way to modify them? Modify the whole table or just the wot portion?
