Page 1 of 2 12 LastLast
Results 1 to 20 of 27
Thread: Histogramm No.1 and 2 only first row - PIDs correct. need help!
    Sep 2004
    Munich Germany
    48
    I havent used the scanner for a while (since i upgraded to version 2.xx). Today i realized that on histogram no. 1 and 2 (Main Spark Timing Adv. and Main Spark Knock retard) the histrogram only displays the first row (0.08 Cylinder Airmass g/cyl - any Speed rpm is shown)). I checked on the PID table and found that "Dynamic Cylinder Air" is in the list and showing proper information of the scann. Its simply not showing up in the histogramm.
    All other histogramms are working fine.
    I am currently running the latest version supported (2.1.12.0)
    Whats the fix on this ?
    Hope somebody can help.
    Thanks,
    Jochen
    Sep 2004
    Munich Germany
    48
    Here a picture of the histogram and PID table:
    PS. forget this link and click on the image link below!
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,268
    we need to sign up over there to view the screen shot...I will say though without even seeing it your probably not logging the correct PID's which is why its going to the first line...common mistake, usually an easy fix would be going back to the default configuration & starting over. FWIW you can upload/manage pics/files here when your posting
    Sep 2004
    Munich Germany
    48
    Upps, i havent seen the attachment section below
    Thanks for the tip!
    Well, on the picture you can see that i have the PIDs required in the table. Thats why i am without a clue what to do. See this:
    HP Tuners Support
    (foff667)
    28,268
    could you post an hpl file as well as an info log for us if you dont mind? what version of the software are you using?
    Sep 2004
    Munich Germany
    48
    I will make that later this day, still at work. . .
    I use Version 2.1.12
    Jochen
    Apr 2003
    Almost 2000 feet.
    7,876
    Also what is your vehicle?
    EC
    Always Support Our Troops!
    Sep 2004
    Munich Germany
    48
    I have a 97C5 Corvette. here the File:
    Operating System: Windows XP
    Microsoft .NET: 1.1.4322.573
    VCM Suite Product: VCM Scanner 2.1.12.0
    VCM Suite ID: 00000A33E5
    Year/Models:
    Chevy Corvette (V8) 1997
    GM Firebird/Camaro (V6) 2001
    Date: 10/17/04
    Hardware: 1
    Firmware: 306
    Part Number: 0
    Type: Chevy Corvette (V8) 1997
    VIN: 1G1YY22G0V5109272
    VCM ID: 0J0PCB7174
    BCC: ????
    ECM Seg 1 ID: 0
    ECM Seed: 43F6
    HP Tuners Support
    (foff667)
    28,268
    ahh thats probably the issue...send your hpt file as well as your info log as well as a link to this thread to support...they should be able to get you squared away.
    Sep 2002
    Chicago, IL
    6,395
    I don't think thats the issue.
    Please post your hpl file and the vcm scanner config file that you are using and we can see what the issue is.
    We got this guy Not Sure, ...
    Sep 2004
    Munich Germany
    48
    Hi Folks,
    thanks for you help.
    I just sent Chris the .hpl file and the .cfg file
    It seems top be a bigger problem now. After applying 2Bar Map SD i couldnt see any window within the editor.
    Please have a look at my .hpl file and see whats the problem is!
    Thanks,
    Jochen
    HP Tuners Support
    (foff667)
    28,268
    would you mind posting your hpt, hpl & cfg files here Jochen?
    Bill
    Sep 2004
    Munich Germany
    48
    I will post the files here tomorrow. There was one point i forgott to do: while upgrading to 2bar SD i used a .bin file which i had already on the HD. Chriss told me to read the pcm file from the car and apply to this file the upgraded OS (2 Bar).
    So tommorow i will read the cars pcm with the V2.12 HPTuners Software and use this file to apply 2Bar SD OS.
    Then i will show you guys the files.
    BTW. i uploaded a while ago my Stock an Hypertech VCM Files to the HPTuners sample website.
    Take care,
    Jochen
    Sep 2004
    Munich Germany
    48
    Here are the files you asked for.
    Sep 2004
    Munich Germany
    48
    And here is the VCM Suite Info file
    Sep 2004
    Munich Germany
    48
    And the config file
    HP Tuners Support
    (foff667)
    28,268
    posted everything except the hpl file that it happened in lol
    Sep 2004
    Munich Germany
    48
    Well, the problem is that all the old scans i made during the last 1.5 years where fine until now. Now all those old files which where OK are now suddenly showing this strange symthom... When i open them with HPTuners Software they just show histogram No. 1 and No. 2 the first row.
    Two hpl files attached. . .
    Log "A" was done in Feb. 2005, Log "L" was done a few days ago. Log "A" did show well untill a few weeks ago. Dont shure if it has happened after i upgraded to Version 2.xx HPTuners Software.
    HP Tuners Support
    (foff667)
    28,268
    both work absolutly fine for me using my default config as well as your config
    Senior Tuner Russ K's Avatar
    Dec 2005
    Regina, Sask.
    4,214
    The histograms work for me as well. I see that the 2 bar SD operating system is not applied. You need to do a write entire for the first time when changing to the 2 bar SD, then just do a write calibration for the next time you make any changes to the file.
    Russ Kemp
