Results 1 to 9 of 9
Thread: New to HP Tuning
    Jul 2006
    8
    New to HP Tuning
    I have a 2006 Corvette A6 and would like to start tuning it. I have setup HP and run a couple of logs trying to get familiar with the process. I have begun reading threads and trying to assimilate a basic understanding of the process I need to go through. It appears the the first step is to modify the primary VE table before moving to the next step. The '06 PCM does not have a Primary VE table, only a Cranking VE table. Related table also do not exist Where should I begin?
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Trenton, NJ
    21,308
    TM, fan temps, maf, pe, spark, etc.
    If I hear when will Dodge be ready one more time...I might do one of these
    Jul 2006
    8
    So the assumption is that VE is correct under all conditions then?
    HP Tuners Support
    (foff667)
    Trenton, NJ
    21,308
    there is no ve table on 06+ corvettes.
    Apr 2003
    Near Ken
    7,877
    The 06 vettes are the easiest to tune yet. Without the normal VE table you only have to deal with TM MAF Spark & PE. (and all the other stuff you normally do...)
    Always Support Our Troops!
    Jul 2006
    8
    How do I deal with TM with an A6 trans. I could not identify a TM enable/disable toggle in any tab.
    HP Tuners Support
    (foff667)
    Trenton, NJ
    21,308
    would you mind posting your file?
    Jul 2006
    8
    I will put it up at home tonight.
    Apr 2003
    Near Ken
    7,877
    TM is in the engine file under TM > per gear ratio. There is no modifying the TCM yet.
    EDC
