Delete thread
Delete thread
There's almost zero usable data in that datalog. Most of the things you are logging are transmission related, and you have a th350. You'll need to set your maf codes back to "fail first". Is it a return or returnless fuel system? What are the oxygen sensors doing? Is it asking for more Braf? Does it set any codes? Did you look inside the PCM to be sure it had drivers for the IAC?
