So over the past year or so I've just hung tight with a VMP BAP and my ID1050x injectors but finally broke down on a full fuel system, had a local shop to me piece together a kit for me and wanted to just share my experience and maybe help anyone thinking about going to a return style system with choosing the right parts. For a little background I have a procharged 2014 Mustang GT, full exhaust, auto(stock converter) & boss IM, made 578 pre boss IM so I'd hope I'm right around 600rwhp now.
The kit that was pieced together for me
on3 fuel hat
(2)AEM 50-1200 pumps
finishline factory nylon braided hose
finishline factory fittings
Finishline factory fuel filter
Aeromotive A1000 regulator
Radium Coyote fuel rails
The Good:
I'm happy with the performance of the AEM pumps, they seem to be doing very well
I'm happy with the performance of the A1000 regulator, it seems to be doing its job very well
The Bad:
The finishline factory nylon braided hose while it might last a little longer than pushlock hose it is permeable meaning if you store your mustang in your 20x20 garage your garage will stink of gas after a short amount of time, if I were to do it again I would definitely have gone with some redhorse pushlock, I should've listened to my friend on this up front but hindsight is 20/20. Like many of you I like working on my car and I will surely be going to pushlock hose whenever this hose fails. I've been told PTFE is a bitch to work with and while its not permeable I would take ease of install/replacement over the hassle.
The on3 hat comes with 10AN elbows at the hat and I'm only running 8AN feed so we had to run a reducer AN fitting off the hat, this had a leak, we believe the leak is due to the on3 fittings as the adapter fitting we originally used was new and appeared fine, I ordered a new adapter fitting from a local company which happened to have an o ring and this fixed the leak.
The finishline factory fuel filter is one of those dinky little ones "modeled after the earls ones" and I was getting major fuel pressure drop at wot(23psi) immediately after install.
The downright ugly
So let me start off by saying I had nothing but issues with the on3 hat as it does not come sealed at the wiring I had to deal with having it sealed using JBweld wait 24hrs for it to cure and we finally got it sealed and, well, fuel decided the next weakest link were the 3 o rings in the hat, so we had to remove the hat, break through the JB weld, take apart the hat completely, replace the failed o rings(from the factory as this was a brand new unit), put it all back together, reJBweld it wait 24hrs, install it, only to find it started leaking again at the wiring so remove again, reJBweld, wait another 24hrs, install & test again...seeing a pattern yet? So for starters I would run from the on3 hat. In addition to the on3 hat there are several other hats on the market that I believe use the EXACT SAME DESIGN! so I would stay away from them as well because of this. Additionally any fuel pump you mount in this hat has to use a short piece of regular fuel line which will break down especially when exposed to E85, I believe this is just a poorly designed hat. Personally if I could do it over again I would've definitely gone with a kit that utilizes a fore 2 or 3 pump hat.
Now with that said the Radium Coyote rails were a bit of a wildcard and I have no idea why these were chosen by my shop, it was obvious they had never used them before the problem with them is the have 6 ports on them but provide you with no hardware for them. So on a return style system you'll typically have an inlet, crossover & outlet, pretty straight forward, but with these 2 of the 6 ports need to be plugged but they don't provide the plugs so during the install this was discovered and plugs had to be purchased on the fly so to speak, yes this does speak to the incompetence of the shop that purchased & installed these mismatched parts and to some extent on me for not being more informed or taken the lead on all purchasing aspects.
In the end I did replace the finishline factory fuel filter with a DW 110 fuel filter from xtreme motorsports out in AZ and it is working great. Along the way I've purchased a bunch of AN fittings from anhosefittings.com and they have all worked great.
Now in regards to tuning, I have both pumps running full time and initially started tuning while being non boost referenced, basically just set base pressure, set the inferred tables to 58psi across the board, set the secondary fuel pump monitor to disabled and tune away ie maf table pretty straight forward. I've since switched to boost referenced and have just started tuning it like this, not really much of a difference at part throttle thus far, with the same base pressure under part throttle rail pressure is typically at 56-58psi like this anyway. Only under decel will fuel pressure dip to 50-56psi.
I would definitely recommend installing an electronic fuel gauge in order to monitor your fuel pressure once in a while(you can usually tell when your fuel filter needs to be cleaned by monitoring your fuel pressure, particularly at wot).
There are many kits on the market including the uber expensive fore kits where they nickle and dime you for parts and yes their fuel hats are awesome but I wasn't spending $3k on a kit. There are also kits like the ones Jn2 sells that include a fore hat and If I were to do it again I'd probably go this route, they are about $1600-1900 but definitely are a big step up from the budget deadhead kits and not really that much more $ in the grand scheme of things.
Well, thats my take, hopefully this helps someone else that's on the fence and just doesn't know which way to go.
