Results 1 to 6 of 6
Thread: C7Z throttle not opening all the way
    May 2018
    29
    Here is log from just now. only seeing low 80% throttle position. any idea why or how i fix this?
    2017 z06
    15% pulley
    intake
    cat delete
    x pipe
    May 2018
    29
    maybe it is, different set of config channels.
    throttle position sae 84%
    throttle position 99%
    pedal position 99%
    May 2018
    29
    also looks like im getting 7-8* of timing pulled out. so it appears it pulls based on manifold temp, not inlet temp
    May 2018
    29
    bump
    Mar 2010
    Texas Hill Country
    3,299
    if your torque model is wrong it will close throttle and retard spark to help output match up with expected power.
    Driver Demand
    Virtual Torque Editor helps you edit your torque model coefficients
    Peak Torque
    are your main areas to recalibrate.
    Advanced Tuner veee8's Avatar
    Apr 2006
    Raleigh, NC
    449
    You are correct in your findings. The throttle is indeed all the way open. The approximate 84% is WOT.
    Also on the LT4 cars the manifold air temp is what is referenced for the inlet air temp multiplier.
    www.crawford-racing.com
    Home of the original and best selling CR-Fueler plug and play port injection controller kits for all GM Gen V direct injection platforms.
