Right now I am running around 17-18* of timing at 17psi on 93. Car runs strong with no issues.
How much more timing can i go if i run either 100-103 octane fuel for the track?
Im thinking around 4* to be on the safe side?
2019 Ford Raptor Tow Rig Scarab 195 Open 250HO
2008 Shelby GT500 VMP Gen II-R (17psi), JLT 123mm CAI, Ford SCJ Monoblade Throttle Body, 56# Injectors, BoostAPumps, VMP triple pass heat exchanger (dual fan), 170* thermostat, BBK long tube headers, Dual resonators, Magnaflow Catback, LC2 Wideband, RXT clutch
I believe my friend ran 20-21* with 112 race gas and 19lbs of boost on his 2010. TVS with 2.39 upper and 15% lower on stock motor. He went 9.87@141.
Dang that’s moving. Ok cool thanks for the info.
I'm running 19degrees on 93 pump 22lbs boost, but 8.8:1 compression
My 2012 with 18-19lbs of boost running Sunoco 260gt threw a rod and windowed the block. It was Lund tuned. Happened after 25 gallons of race fuel.
Ouch....wouldn’t happen to know how much timing that Lund tune had do you?
I can check one if my old data logs for the timing, my red line was 6500 and the rod let go at about 3/4 throttle and 5000 rpm?s
