Results 1 to 2 of 2
Thread: Strange timing
    Nov 2005
    Someplace high in the Himalayas
    770
    Strange timing
    I ran a lot of passes this weekend and I can't figure out why I have a dip in timing in first gear. The IAT shouldn't be pulling timing.
    Also, what do you think about the TM in the image, is it too aggressive? Am I losing a lot of time?
    Why am I seeing knock when TM kicks in?
    www.outlawpontiacdragseries.com
    Come race with us in MA, PA, and VA!
    2005 GTO A4 - Spintech X-pipe with Powerstick mufflers, IAT relocate, Volant, !scoops, !cowlgasket, !skid plate, LM-1, HPT2.0/MPVI Pro USB, 275x40x17 Nitto DR, rolled fenders, Pedders 2985 springs, Britax baby seat with 5 point harness.
    Stock:13.36@104
    Mods in sig:[email protected]
    Nov 2005
    770
    Figure the timing out atleast. Seems my IAT was 122* when I hit the throttle and it rose to 124* at the middle of the gear which kicked in my -3* IAT spark correction. Then when it hit second the air started to go down in temperature and ended up at 109* at the top of third. This is interesting. It means it has to suck the hot air out from under the hood first. You would think a little speed would push colder air in and get registered long before the top of first gear. These GTO's have horrible ventilation...
    Stock:13.36@104
