Results 1 to 5 of 5
Thread: Deatschwerks 88's RICH all the time!
    Scaled using their data. Car ran fine before injector swap. Scaled IFR up to experiment with no change. VE table doesn't seem to change anything. I suspect it's a pulse width problem. I know I could adjust the Offsets table but I'm thinking something else has to be holding it up. I have read about the Transient fuel tables but from calculations I should be able to achieve 1.40 ms but am seeing 2.6 ms minimum at idle. Figured I would try for suggestions while I don't have access to the car till the weekend. Thanks
    Mustang1.hpl88 Mustang Phil 3 bar.hpt
    13,565
    Sometimes people have to cut the min fuel grams in half if all other data is correct.
    Or just yank 20-30% from the VE to see what happens.
    Apr 2011
    Chicago, IL
    763
    what size injectors were you at vs now? is the data correct? if they were changed to pretty large injectors you probably just need to remove a decent amount of fuel from your ve or maf charts whichever you use
    edit - you have maf failed but dynamic airflow is still set to 4k - if your speed density only raise that to 8k
    Was using 44 lbs that worked well with only scaling the IFR. Now I have 88 lbs. Data came straight from Deatschwerks. VE table down in the teens with fuel trims still at -40.
    Apr 2011
    Chicago, IL
    763
    id maybe try 1/2ing your injector offsets in the vehicle operating voltage range from like 12v to 16v and see if it helps
