Im in need of some help it seems i cant figure this out to save my life. I cant seem to find out why the truck wants to fall on its face like. I've tried everything to adding fuel to taking fuel away. I cant even get a base tune to work off of to start tuning the VE table. First the truck struggles to fail the maf right away but once it does it will idle perfectly fine. If the ECT is low and the IVT is low the truck seems to not fall on its face as much but gets worse as it warms up. Can someone look at the tune and see if anything is way off? From the log it looks like in some points the TPS and Advance drop off while the rpm and and map keep climbing. Im new to tuning in boost so bare with me. Truck has 1000cc injectors with doubled stoich and halved IFR, IVT terms. Also has COS 2 Bar
1-22-17 COS.hpt
1-22-17.hpl
1-22-17(1).hpl
