-----Original Message-----
[email protected]>
To: Kingtal0n <
[email protected]>
Sent: Sat, Mar 28, 2015 3:10 pm
Subject: Re: TFX Engine Technology Inc. - Price inquiry
Hi,
You have a bit of a unique situation. A complete system consists of 3 main components:
TFX Analyzer + Pressure Sensor(s) + Crank Sensor (or MVCSA adapter).
Lets assume as a start that you wish to go with an instrumented spark plug instead of a head mounted sensor, and that your engine already has a crank sensor, then the least expensive solution would be:
TFX 1 Analyzer ($3395)
1 pressure channel, 1 crank sensor channel, live data display capability, includes all software and updates.
Instrumented Spark Plug ($1495 each)
Suitable for NA to 40 psi boost. M14 thread, 19 mm reach, gasket seat (other dimensions available).
MVCSA (Multi Vehicle Crank Sensor Adapter) ($425)
Allows the analyzer to connect to the engine's existing crank trigger signal. Works for low voltage and high voltage crank triggers. Suitable for a wide range of trigger patterns i.e. 60-2, 36-6, 36-1, 24-2, 24-1 etc., and if you encounter a particular engine which has a trigger pattern that is not already in our library, we will generate the necessary code to add it to our library. No charge.
The total would then be $5315 + shipping.
If you feel that you would not need the equipment beyond your thesis we would then purchase the equipment back from you for $2500 assuming you keep the equipment in working order and are finished your thesis within 1 year of the purchase. That would make the overall total $2815 + shipping.
If this is something you would like to pursue let us know the contact details, university details, and the engine details, then we will prepare and official quotation for you.
Thanks,
www.tfxengine.com
