Is there an easy way for correcting my VE table.Right now iam doing
caculations for each spot and its over a 100.
More info would be helpful, like your vehicle and mods. But to directly answer your question, yes it is fine to exceed 100% in the LS1 VE Tables. The number is irrelevant, so long as the fuel and timing is correct.
It should be very easy. Copy the entire histogram table for AFR error, then right click the VE table and select Paste Special Multiply By %. I beleive that is what you want.
Open the help file and search for Speed Density. There is a tutorial that explains it.
I dident explain to clear but i need to right click and paste,but some are off
by 1% to 10%.If i did enter a % number they all would go up by that number.Iam doing each cell now because they are all different.
It will do that for you. When you paste special Multiply By % it will multiply each cell by the % in the corresponding cell from the Histogram. You don't enter a % value, it comes from the Histogram. That's why you need to copy the entire Histogram and paste it (special) into the VE.
For instance, if cell 1 in the Histogram is 3, and cell 2 is a 7, when you paste special it will multiply cell 1 in the VE by 3 and cell 2 by 7.
Try it! You'll like it!
thats pretty neat,ill save a few hours
thanks
I have some spreadsheets I use... if you want them let me know.
I know alot of guys use the Paste Special feature but there are times I would rather go through the spreadsheet to hand manipulate some data. The other benefit of the spreadsheet is that I have it generate the secondary VE table when needed.
Tim
Ok,might be handyOriginally Posted by Tim05GTO
thanks
Here are the files... I made these for my personal use. Some may find them useless but for me there are times when they come in very handy, particularly the MAF sheets.
Tim
