Results 1 to 9 of 9
Thread: Correcting VE table
    Tuner dc96819's Avatar
    May 2004
    Long Beach Ca
    121
    Correcting VE table
    Is there an easy way for correcting my VE table.Right now iam doing
    caculations for each spot and its over a 100.
    Jul 2004
    1,579
    More info would be helpful, like your vehicle and mods. But to directly answer your question, yes it is fine to exceed 100% in the LS1 VE Tables. The number is irrelevant, so long as the fuel and timing is correct.
    Feb 2006
    PAC NWest
    396
    It should be very easy. Copy the entire histogram table for AFR error, then right click the VE table and select Paste Special Multiply By %. I beleive that is what you want.
    Open the help file and search for Speed Density. There is a tutorial that explains it.
    May 2004
    Long Beach Ca
    121
    I dident explain to clear but i need to right click and paste,but some are off
    by 1% to 10%.If i did enter a % number they all would go up by that number.Iam doing each cell now because they are all different.
    Feb 2006
    PAC NWest
    396
    It will do that for you. When you paste special Multiply By % it will multiply each cell by the % in the corresponding cell from the Histogram. You don't enter a % value, it comes from the Histogram. That's why you need to copy the entire Histogram and paste it (special) into the VE.
    For instance, if cell 1 in the Histogram is 3, and cell 2 is a 7, when you paste special it will multiply cell 1 in the VE by 3 and cell 2 by 7.
    Try it! You'll like it!
    May 2004
    Long Beach Ca
    121
    thats pretty neat,ill save a few hours
    thanks
    Dec 2005
    Orlando, FL
    92
    I have some spreadsheets I use... if you want them let me know.
    I know alot of guys use the Paste Special feature but there are times I would rather go through the spreadsheet to hand manipulate some data. The other benefit of the spreadsheet is that I have it generate the secondary VE table when needed.
    Tim
    May 2004
    Long Beach Ca
    121
    Quote Originally Posted by Tim05GTO
    Tim
    Ok,might be handy
    thanks
    Dec 2005
    Orlando, FL
    92
    Here are the files... I made these for my personal use. Some may find them useless but for me there are times when they come in very handy, particularly the MAF sheets.
    Tim
