Details 2002 Z06. just did an LS2 swap. it's an 2005 LS2 24x reluctor, 1X cam gear.
initial first start up
https://www.youtube.com/watch?v=JohoUaQ-d0w
warm start, car has an SD tune. Maf there for the IAT
https://www.youtube.com/watch?v=B6VOvKNYoFw
wired in IAT sensor, bleed cooling system, everything still cool.
https://www.youtube.com/watch?v=CoNCkMWjz0s
another hot start. At this point, I noticed the CEL P0101-P0103 which is MAF that i just removed to wire in IAT, DTC P0343 popped up, Camshaft Position (CMP) sensor Circuit High voltage, car still starts and runs at this point. I start looking around for info on the DTC, appeared the code is generally GenIV motor with GenIII pcm related, Cam bolts backing out, or cam sensors wires need to be switched. Engine has new front cover, new cam, New roll master 1x timing set, new crank sensor, lock tight cam bolts. so unlikely with bolt backing out issue. top end has like 25mins of run time on it.
found this schematic on cam sensor. I do have 12v going to the sensor. dunno what happening after that yet.
Still running at this point
https://www.youtube.com/watch?v=3oJ3C9JR8kk
go to bed and it just won't start run anymore. when it does, it's for a few second, then it dies. I started focusing on that code. I switched the A and C cam sensor wires, the code did go away, but it still wont run. I switch the wires back and the code back. now I'm uncertain how relevant is that code to my diagnosing.
https://www.youtube.com/watch?v=tLfz5uLzUP4
and I do have fuel pressure, 58psi on my mechanical gauge....I need ideas on where to look, can the cam sensor be logged somehow? i haven't found that channel
the logs attached is from it running bleeding the cooling system going through its heat cycle
then cranking with wire switch
then switched back
