Results 1 to 12 of 12
Thread: Custom AFR Error Math for histogram
    I am trying to write the math for afr error on a double stoich tune to set up a ve afr error histogram
    Does it look right see photo
    100x(AFR-command*.5)/(command*.5)
    So first would be the afr command x 50% or .5 because command is double. next afr - your newly halved command. Then x 100 and Divided by halved command to get percentage.
    Should I post this in miscellaneous ?
    Jun 2011
    Montreal, Canada
    758
    I use the math parameter as it is in HPT and it works fine, but tuning in lambda.
    2007 Corvette C6 Vert. A6
    LME LS402, Pat G custom cam, ATI 10% OD Damper
    Circle D triple disc 2600, 3.42 Diff
    YSI, 3.0 pulley, ID 1000's
    Alky Control Meth,
    ARH 1 7/8 headers,
    1009 RWHP @ 7000, 817 RWT @ 6000
    Senior Tuner mowton's Avatar
    Mar 2007
    Florida
    3,773
    Double Half scaling AFR math
    Here are the two pieces of math needed if you are tuning in AFR..... Update your Chart, Graph and any filters using commanded AFR as required...
    Another good reason to tune in Lambda
    Ed M
    [email protected]
    Quote Originally Posted by mowton View Post
    Ed M
    Quote Originally Posted by realcanuk View Post
    I do normally too but the pcm has a hard injector limit of 63 lbs and I have to do the double stoich method to get the new injectors to work. So when I am logging and read 14.7 afr or 1.0 lambda the commanded is 29.4 or 2.0. This makes the histogram read incorrectly.
    Senior Tuner Lakegoat's Avatar
    Jul 2012
    Florida
    1,460
    Did you half IFR and IVT Terms? Mine is double stoich and I have no trouble using Lambda. Using AFR would be a different story.
    2013 Silverado 5.3, 6L80k 8.8
    Quote Originally Posted by Lakegoat View Post
    Yes
    I should use lambda since i have a flex fuel sensor.
    Jan 2014
    Australia
    1,984
    Quote Originally Posted by ProFire View Post
    Lambda never changes if u double stoich the 29.4 is still lambda 1.0 thats why it works in all fuels, then just use eqratio v lambda for your error
    Thanks I will try it out
