Corvette C6 2006 Steering Coulmn Service Disabling
Hi and best regards to everyone, I'm new here.
Somebody knows if can I eliminate the column lock service by dissabling VATS 1, VATS2 or Starter Fault Checks?
Ernesto
The message originates from the BCM and the ecm shuts the engine off over 3-4 mph after it's been started.. There might be something in the editor to turn it off but it won't be with vats or starter fault checks, but your still going to see the message on the ipc..
The best fix imo is from http://www.complianceparts.com/index.html LMC5 module is installed at the BCM, clean and simple to install..
thanks tek1229, nice link, but seems it is only for C5, I know others bypass for C6 and I did on other C6, but this time I'm trying to find the way of do it by software, this C6 is Euro version also with intrusion tecction.
