Can someone look at this tune and log file? This truck is impossible to cold start. I know the MAF is set to 0 as it's in Speed Density mode (due to a wiring issue with the MAF). When you unplug the IAC the truck wil start and run if you plug the IAC in while the truck is running the idle will smooth out and it will even go as far as recoving when you rev it (IAC count is also sub 100). However shut the truck off and try to start it again (even immediately when warm) and it just will not. It fires and immediately dies.
2001 LQ4 Swap
Custom harness
408 CI Texas Speed stroker motor
102MM FAST inake
Below is the current tune and log file. You can see when the disconnected the IAC and it started. Then when the IAC was plugged in the idle smoothed out. To make things worse the truck is 3,000 miles from me so everything is having to be relayed and one tuner already took a (mail order) crack at it.
