Results 1 to 6 of 6
Thread: High air intake temp
    Dec 2017
    20
    Hei guys.
    I have my LBZ silverado. With a stage 1 turbocharger mounted on it.
    But it is explowding in the air intake temp.
    If im crusing with about 6-70mph it is about 120-140degres farenheit. This is about 7-8 psi of boost.
    If i take a long pull. It can rice up to 180 farenheit. Where I will lift the food. :-(
    Does any of you know if this is right??
    What is the temp on your trucks??
    Thanks Jonas.
    Quote Originally Posted by Jonass View Post
    Hei guys.
    Thanks Jonas.
    Seems about right. May be a bit high. if it matches ambient temp with zero boost it should be correct under load or boost. If your turbo is inefficient it will be high !
    Dec 2017
    20
    Hi.
    Okay....
    But it is a brand new turbo. Have been running 1000miles now.
    What about a EGR valve?? Tho it dossent get any errors on that..
    May 2016
    Adelaide, Australia
    246
    Whether the turbo is new or not has nothing to do with the heat it will generate.
    What intercooler and where is your iat sensor mounted?
    Dec 2017
    20
    Hi.
    It was the EGR valve. I blocked it. And tempreture droped to 40-50 degres fahrenheit above tempsensor in the MAF.
    EGR crap. 😊😊
    Those are definitely not normal cruising temps. Intake mani temps while cruising should be well within 15-20* ambient, sometimes even lower. Even after a long hard pull you should barely be seeing those sort of temps.
    09 Cobalt SS - E47+EFR6758 =
    07 Silverado ECSB LBZ Duramax - Bunches of goodies
