Results 1 to 20 of 20
Thread: misfiring
    Jul 2006
    25
    misfiring
    Ok guys so I got this mailorder tune and It kept throwing a code. P0300 general misfire. Well I got my HPtunes and now and I tried a BUNCH of stuff to make it go away. I bumped the MAF setting up 1.15 and still nothing. I just set my timing retarded across the board. It is now lower than the stock timing. I did some loging and I noticed NO knock. What can be done to fix this? Below I added the tune I got from the mailorder place, what I tried to fix, and the log I did.
    Nick
    Dec 2005
    Orlando, FL
    92
    What are your mods?
    Jul 2006
    25
    Arizona speed and marine headders, 160* T-stat, Comp cams firewire spark plug wires, custom bent free flow cat back, and im installing some LS1 fans tomorrow
    Dec 2005
    Orlando, FL
    92
    I would suggest you log the misfires for each cylinder and see if it is isolated to one cylinder or is global. A log of this would be very helpful as would a log of normal parameters.
    I can only speculate right now but I would swap plug wires with a set of stockers and see if this goes away. Tuning shouldn't be causing misfires unless it is really out of whack.
    Tim
    Jul 2006
    25
    um... stock plugs with new wires, new plugs and new wires, new plugs and stock wires, and stock plugs stock wires were tire still nothing....I dont get the code when im on my stock tune tho!
    Nick
    Dec 2005
    Orlando, FL
    92
    Good info. I'll take a closer look at the tune.
    Can you post the stock file?
    Tim
    Tuner kabbott's Avatar
    Sep 2004
    Ba co. Md
    121
    Quote Originally Posted by Tim05GTO
    Tim
    ya that would make good use of the compare feature.
    2000 Impala 3.8
    4T65Ehd 3.29
    VCM ID:7DS739259ui
    VCM OS ID:9387047
    Dec 2005
    Orlando, FL
    92
    I pulled a stock 03 file. I noticed in the PCMForLess tune that the idle timing is set to 28 degrees in the area where the car would be idling. Try setting those tables to stock in the PCMForless tune and see how it behaves. There may be too much timing there.
    Tim
    Jul 2006
    25
    good idea, the truck idles like crap!
    Jul 2006
    25
    Ok guys I pulled back timing in the high octane and low octane settings, increased the maf setting, and put the IAT spark advance table to stock and put the stock plugs and wires into the truck. I AM STILL GETTING THIS P0300 code! This is getting abnormal. I noticed the long ter bank injectors were in the read with the IAT's (the injectors were 15% and the iat was 104*) but I changed everything to stock with the exception of the e-fan controls, and speed limiter.
    WHAT TO DO!
    Nick
    Dec 2005
    Orlando, FL
    92
    Please log the misfires for each cylinder and post the log...
    PID List -> Engine Diagnostics -> Misfire -> Misfire Current Cylinder #1 - #8
    Also RPM, TPS, MAP, and Advance and KR.
    Tim
    Jul 2006
    25
    Where is the PID list? I don't have the pro interface? When im in the VCM scanner I have file, scan, display, tools, windows, and help?
    Dec 2005
    Orlando, FL
    92
    Display the table... right click on that to insert a new PID.
    Jul 2006
    25
    OK! i got that. Will have somehting in the morning after I finish my E-fan swap!
    Jul 2006
    25
    I changed the PCm in my truck to the stock one and tried to upload the pcm tune, the bad one i mean. It wouldnt accept it. Is there a way to change the OS of the tune to let the file go from one PCM to another? I uploaded the high and low octane tables onto the stock tune I had and ran a LOg car wouldnt start at first and than when it did I got this log.
    Jul 2006
    25
    Changed out the computers and it still runs like crap......
    Dec 2005
    Orlando, FL
    92
    Try running the CASE Learn procedure. Details can be found in the help file. Just search for "CASE Learn" and follow the directions.
    Tim
    Nov 2002
    Central Florida
    2,503
    Instead of changing tune elements, try logging the
    current misfire (cylinder mode) and misfire history
    for all of the cylinders and see if it points you to a
    bad boy. A large cam, light converter will simply
    elevate misfire counts. You may just want to bump
    the thresholds up to make it quit nagging but you
    want to know what the problem is, first.
    Dec 2005
    Orlando, FL
    92
    Jimmyblue,
    The last HPL posted has the misfires logged. The timing is extremely erratic.
    Tim
    Jul 2006
    25
    I looked up CASE c a s e c.a.s.e crank and crankshaft and nothing came up.... I have the brand new version 2.12?
