Results 1 to 3 of 3
Thread: OS tune for L92 VVT and manual tranny.
    Feb 2018
    Sweden
    10
    Hi,
    I think I need a new OS for my L92 from an Escalade 2007. I'm using a manual tranny (TKO600) and I want to keep the VVT, what OS shall I use and where do I find it?
    I'm a rookie who just installed HPT Pro...
    Advanced Tuner VodeAn's Avatar
    Jun 2012
    230
    You can do all that with the stock OS, set the transmission type to Manual, and turn off all the Auto trans related DTC's. If removing the TCM, you'll need to run the can Data wires from the ECM to the DLC (OBD 2) port. From the factory, the CAN data wires run from the ECM to the TCM and then into the vehicle.
    Feb 2018
    Sweden
    10
    Thanks VodeAn! I feel much better now.
    I will use the electric oem accelerator and a goldblade TB on a LS3 intake and have connected the spliced brown and brown/black wires to the OBD2.
    I accidently removed the VSS wires from the E38 ecu connectors, but will hook them up again and hope that they'll work with the VSS stock on the TKO600 (2-pole).
    Best regards
    Mike
