Results 1 to 3 of 3
Thread: How to correct my wheel torque errors along with other TQ errors
    I have a 15 mustang GT with GT350 TB and Holley intake i have copied a stock file from a GT350 for all the electronic throttle data and adjusted the IPC,Driver Demand, Torque and Spark tables. i see at some points in my log i have up to 154 wheel tq error at 2655rpm and then its pretty low until 2900-3100 rpm.
    I'm trying to figure out how to take my charts and figure out what to adjust to reduce the errors I'm logging ETC TQ request,IPC Torque errors and Schduled torque under torque source it log it says driver demand so do i need to change my driver demand tables and if so how do i use the charts from the log to correct all the errors with Torque? Thanks
    i attached tune and log to this postnew part.hplMAF Tuning Final 2 part throttle copied gt350 tq tables driver demand and ipc tables along with .hpt
    Tuner TunedByNishan's Avatar
    Sep 2014
    Wood-Ridge, NJ
    106
    Did you also swap over the Sensor slopes for the GT350 TB?
    www.tunedbynishan.com
    2018 Mustang GT - 10R80
    Yes I copied all data under electronic throttle
    Quote Originally Posted by TunedByNishan View Post
