LS2 to LS7 swap
I have just completed the above and need to know how to turn off the check oil level warning in the DIC as I now have a dry sump system, Thanks
There should be a engine oil level diagnostic. If you turn that off it may work. The issue may be if the BCM is what is looking for it....
Thanks, I'll check into that.
I have a zo6 that I put a 4l60e transmission in. I used a base corvette tune to make the transmission work. I am also getting the check the oil level in the DIC. Since the BCM in my car is still the zo6 BCM it must be in the base tune in the ECM. But, I can't find it. Have you been able to resolve this with your car?
No, the light still comes on periodically, wondering if I change setting to "No MIL Light" if that would do it. I take it that the level circuit reads open if not connected and closed if grounded to engine. I'll have to check my service manual wiring diagrams.
I think it works by sending a ground to the ecu when the car has oil. If the oil gets low it will unground the ecu. If the connector that went to the oil level sensor has two wires then connect them together and that should make the car think it has oil had turn the light off.
