HP Tuners Owner
if you're looking at the area near frame #4940, i doubt that is AE related. AE is used to cover lean spots during positive throttle transients. It only lasts a short period.
It looks like your MAF table needs tweaking downwards or you have the injector flow rate set too small at low vacuum (high MAP).
Chris...
Any additional info on the DE side of things.
When I let off to 0%tps on the highway and going over 2300rpms, my rpms will fall slowly for @200rpms and then fall instantly about 600-800 rpms and the wideband will flash 19.xx. It stays like this while it drops another couple hundered rpms and then it will bounce back up a few hundred rpms and be fine.
