2010 camaro system running crate 6.2 with 4l60 swapped in a chevelle.
Trying to tune the car on a dyno. Keep getting torque management advance that seems to be pulling timing. It can pull 1-10 degrees and anywhere in the 2-5 range that Im testing. look at the attached log towards the end. That time it pulled just over 9 degrees as I got into it. During the run it is pulling timing. So where is the table that is telling it to pull this timing and how do I disable it?
