I have 60lb/hr injectors on my lsj 2.0L and we are running into a problem. The maximum injector flow for the ifr vs map table is 63.49. With these injectors the map is maxed out over 3/4 of its range. Is their anyway to increase the resolution of this map so the ecm can get accurate data so it'll quit throwing rich codes under part throttle?
There is also another small glitch in one of the spark tables I'll ty to find at home today
And the fan control still doesnt work in the scanner
Lastly...does the blackbox logging have less resolution than laptop hookup? It seemed lke my scans had more data when I scanned with the laptop hooked up than when I did it with just the box
Thanks,
Dan
