I need to read an LS7 Edit file with the HPT software. Is it possible??
should be...guess it depends on if/how its locked.
I opened up HPT and tried to open it directly off my desktop as a edit file. Didn't like it so I tried changing the extention. Didn't like that either.
Its an LS7 file so I don't know if it makes a difference or not. Also I have been using the HPT on an LS7 car already.
What did you use to get the file? Unless its a .hpt or .bin format, or reading directly from the ECU in question, HPT won't open it as far as I know.
2.4L Twin Cam Cavalier Z24 | T3 Super 60 @ 9 PSI | FMIC | TurboXS RFL | Greddy Profec B Spec II | Custom HO Intake Manifold | 2.5" Charge Pipes | 2.5" Downpipe | HP Tuners | 5 Speed Swap | Team Green LSD | SPEC Stage 3 Clutch | Fidanza Short Shifter | Prothane Control Arm Bushings | Carbon Fiber Hood
yeah i meant you can READ the file from the pcm...you cant open an .ls1 or .ls7 file or whatever their file extension is now. You'd need to hook to the vehicle & pull the file.
