Results 1 to 11 of 11
Thread: 2011 Ecoboost F150
    Oct 2017
    25
    2011 Ecoboost F150
    I'm wondering what is the max boost the turbos on the F150 ecoboost will efficiently make. I know the sho will do 15psi, but from what I've seen, the truck runs 15psi stock. Any help would be great.
    Jun 2017
    South East Georgia
    127
    The SHO and the F-150 use different turbos. The F-150 uses a K03.
    Oct 2017
    25
    How much boost can these turbos support before heat soak?
    Tuner in Training qck2spool's Avatar
    Fresno,CA
    12
    220-230kpa
    Oct 2017
    25
    Above atmosphere, or from vacuum?
    13,588
    17-18psi of boost, it seems over that it's just making heat from everything I've read in my free time.
    Oct 2017
    25
    So the 15 pounds is about it. Well that sucks. Thank you. I'll make sure to upload my tune in a but. It has a little compressor surge when you shut the throttle.
    Advanced Tuner IARLLC's Avatar
    Aug 2016
    945
    No. Like 5FDP wrote, the F150/Expeditions get 17-18psi easily. Which with good 93 octane often equals a high 12/low 13 second truck...with very few mods. I don't think that sucks.
    The SHO and Explorer get about 15-15.5psi before losing efficiency. Also not too bad.
    Oct 2017
    25
    No, doesn't suck, but I was thinking they would have been a little further from maximum than 2-3psi.
    Jul 2010
    371
    is that 17-18 peak or at redline? Those little baby k03s ought to be able to crank out over 20 psi in the mid range before they run out of flow up top and you have to taper the boost down.
    1994 Mazda Miata turbo, aero, hoosiers Class=SSM
    Take my drop box referral and we both get an extra 250 Mb free!
    Jun 2017
    South East Georgia
    127
    They can easily make more than 18 PSI at 3000 rpm, you have to be careful though because the turbos at that rpm can actually over run the throughput of the HPFP which results in a cascading loss of fuel pressure and severe lean condition.
