Results 1 to 7 of 7
Thread: How to soften throttle response at low speed?
    Dec 2017
    14
    I have a 6.0 LS in a 68 Cutless. The throttle is so responsive at low speed that it's hard to not chirp the tires at stop lights. How do I tone it down? Thanks.
    13,576
    Switching to a cable setup for sure would solve most of the problem but that's not exactly an option for you that's easy.
    Unfortunately that calibration is designed for a truck that weighs like 5,500-5,700lbs compared to your car that is likely 1,500-2,000lbs less so even light throttle movements are going to be "enhanced" because of the weight difference.
    The electronic throttle control limits under torque management are already so slow as it is. The ETC TPS MAX table already has the throttle opening very slow at low rpm to try and keep traction.
    Do you by chance have a log file of it driving around?
    A tune that is not super dialed in can also cause issues with drive ability, like if the airflow model is off and timing isn't all set right for the engine. If anything is aftermarket like exhaust, intake manifold or that kind of stuff it could all contribute in some way if not accounted for. And just from looking at the tune it looks almost 100% stock.
    Advanced Tuner jsllc's Avatar
    Sep 2015
    Bozeman, MT
    701
    Try these values for all cells in 33000 and 33002
    0 0.097656 0.185547 0.351563 0.634766 0.810547 1.259766 1.621094 2.177734 2.910156 3.847656 5.449219 7.226563 9.257813 11.49414 13.88672 16.50391 19.25781 22.28516 25.64453 29.96094 33.39844 37.53906 42.48047 49.21875 55.67383 62.12891 68.58398 76.28906 82.85156 89.32617 94.66797 100
    13,576
    That may help too, it's just such a fine line it seems sometimes. Go too far and it's REP mode like you flipped a switch lol.
    Dec 2017
    14
    Thank you
    -I have entered the suggested values in both tables and will try it out tomorrow. Do I need to worry about the warning about incompatibility with the TAC module? If these values don't provide the driveability I'm looking for I'll post a log to see if it shows areas for further improvement. Thank you both for your guidance.
    Sep 2015
    Bozeman, MT
    701
    If there is an issue it will REP. I do not believe it should with the adjustments made.
    Sep 2008
    1,668
    I know it's not an easy change...but if you're not able to mellow things out in the tune, a higher stall converter can help quite a bit...and the added benefit of it being quicker on sticky tires when you do stand on it. I have a built 370 with a big turbo and a 90mm LS3 throttle body in my Silverado with no weight on the rear tires...but with the circle d 3400 stall it's actually easier/more controllable off idle than the stock 5.3 and stock converter were. The engines so responsive and has so much torque that it's really nice having the converter there to soak it up when I'm trying to blend in with "normal" people.
    2010 Camaro SS M6. Stock Bottom End, Heads/Cam/Intake/Headers/Exhaust.
    2005 Silverado RCSB. Forged 370 LQ9/Borg-Forced Inductions T6 S484/Jake's Stage 4 4L80E with D3 Brake/4WD.
    2023 Durango Hellcat
