Results 1 to 9 of 9
Thread: 406 SBC running 2001 5.3 computer
    Nov 2016
    19
    New to HP Tuners. Anyone have ideas on were to start with my engine project? Thanks.
    Feb 2016
    Texas
    534
    Look on some of the obs (old body style) gm and chevy forums and look for lextech. Pm him or get his email from someone he will be able to get you a spreadsheet for wiring. What vehicle will this be going in some more details would help tremendously.
    97 ext cab short bed silverado 5.7 411 swap, edelbrock 29135 intake, lightly ported 906 heads milled .035 thou. factory press in rocker studs & rockers, comp 787 retainers & stock locks, ls6 springs. Comp cams 08-503-8 T56 swap
    86 SWB crate vortec 5.7/th350 The wife's truck
    Nov 2016
    19
    It's going in a 84 vette. My issue is programming for a gen1 sb. Do you go about tuning as if it were a LS? I would think spark and knock sensors are going to be different.
    Feb 2016
    Texas
    534
    Its a whole different animal. As long as you have p01 computer (411 pcm) you can use an express van tune file from 01- 02. This is really the only way to correctly setup a pcm to run a gen 1 sbc. Look in the tune repository for an express van tune closest to your setup and begin the process from there. Remember if it were easy everyone would do it.
    Jun 2012
    225
    You will need to put the LS sensors on your SBC engine. The big thing is getting a crank sensor that will work with your pcm and engine. I think you would be better off with a holley system or fitech. It may be cheaper in the beginning but the 5.3 setup will cost you more in the end. Plus the holley or fitech use a wideband 02 sensor where the 5.3 uses a narrowband 02 sensors.
    Nov 2016
    19
    The set up is complete with 24x set up.
    Heres a link to EFI Connection.
    They make what you need.
    https://www.eficonnection.com/home/c...x-product-line
    Nov 2016
    19
    The engine is already complete. I as just wondering if the original 5.3 tune is a good starting point or copy a tune from a 5.7 express van.
    Feb 2016
    Texas
    534
    pick your poison I suppose. We are still lacking information about the setup. What transmission will you be using? auto or manual th350-400, 4l60 or 80e maybe even a powerglide. im running an express van tune with a H/C/I 5.7 and a 4l80e with a 411 pcm. If you are also using the same p01 pcm some of the express van tunes in the repository might be of great assistance to you. No matter what, you need to start from the top and work your through the entire tune to set it up best to suite your engine trans combo.
