Results 1 to 9 of 9
Thread: Injector Duty cycle 142% ???
    Advanced Tuner NJ_Phil's Avatar
    Jul 2016
    Flanders nj
    283
    So I got this guy with a built out CTSV running close to 18 psi, who asked me to look into his tune and first thing is to look is scan a few pulls and noticed his Injector duty cycle is close to 150%.
    Told him no way I was touching the car until I put new injectors in and he said his tuner said the Duty cycle shown in HPT isn't real and his tuner just ignores the reading.
    He wasn't sure what injectors he had it, thinks 85lbs and basically told him to come back when he was ready for new injectors.
    Question is how come the motor is still in 1 piece running at 140+% with no sign of knock and no sign of leanout on the narrowband sensors (> 900mv). Knock settings are stock in the tune.
    I mean this guy pushes this thing hard, shifting at 7400, 18psi and deep in the 10s running 1/4 mile all the while with injectors running over 28ms pulse width.
    2012 C6 Base, Kooks 1-7/8" LT, Catted, NPP
    Novi 1500SL, 10% OD IW, Big Blower Cam, Flip Drive, 2x Alky, ID1000
    Nitto NT05R 305x19, 255x18 on CCW T10s
    Self built and tuned https://www.youtube.com/watch?v=Kod2UTqrVwM
    13,565
    Is it an earlier computer that has a max of 63.5lb/hr on the injectors? Maybe he didn't scale the tune properly for the larger injectors.
    To say the readings in HP Tuners is false is stupid, kinda sounds like he doesn't know what he's saying.
    Jul 2016
    Flanders nj
    283
    It's a late model E67 and allows 127 lbs/hr.. Nothing is scaled as far as stoich and IVT.
    Agree that was a stupid thing for his tuner to say but I'm puzzled how it can run at that duty cycle.
    Some quick math shows 7000rpm is a revolution every 8.5 milliseconds * 2 for intake/exhaust cycle means the intake valve is opening every 17ms, yet the injector pulse width = 25+ milliseconds
    I gotta be missing something
    EDIT:
    Just did dome quick calculations on one of my scans that showed 63% duty cycle running at 6700rpm with a pulse width of 11.3 ms.
    6700 RPM = IV open rate of 18 milliseconds, so 18 ms would be 100 % duty cycle
    11.3ms / 18ms = 62.7% calculated, scanner shows 63% so it's a simple calculation to get duty cycle from PW if RPM is known.
    The guy had to give be the wrong tune and I need to upload the actual tune from the car. Gotta feeling something is scaled and he's really running half of 145%
    Tuner dreksnot's Avatar
    Jan 2015
    Loveland, CO
    147
    Can only possibly run at 100% IDC. HPTuners spits out a calculated IDC with pulsewidth, pressure, flow, etc. parameters. As for the injectors being max'd out, they're keeping up if the actual AFR is the commanded AFR. However, it could be at 80%, 90%, 95% or 100% real IDC making that happen (but nothing over 100%). Definitely wouldn't hurt to increase injector size and fueling.
    I've been a culprit of this phenomenon with 125% IDC until I corrected my VE tables. With the same conditions, I am now at 90-95% IDC on the same runs.
    2013 Camaro LSX433 with TFS 245cc cat heads
    AGP 65/65 Twin Turbos into BTR Equalizer intake
    BTR 237/247 .610"/.601" 116+5 (10* overlap) cam
    ID-1700x on AGP Fore Triple w/ Flex Fuel sensor
    Cortex EBC | n2mb WOT box | custom anti-lag
    Potential Tuner crewdoguh60m's Avatar
    Nov 2017
    Oahu, Hawaii
    8
    new street test.hpl maybe his V is as jacked up as mine. you can see at one point I put mine into 141% duty hopfully someone can give us the answers I need
    2012 Jeep SRT 8 392
    SW full exhaust system
    magnuson S/C kit
    BC suspension
    Tuning Addict
    Jan 2015
    6,813
    As long as you keep raising the MAF or VE the injector duty cycle will keep increasing... It's been my own personal experience that the LSA injectors max out around 130% - will not add fuel above that... I do not personally like to go above 90ish especially on something like ethanol because a few percent on the injectors can be a lot on the wideband... There are "off" settings designed into the calibration - that I'm trying to get added - that defines how long an injector can spray regardless... In other words it will only spray so long before taking a break for so many ms and then spraying again...
    If your over or around 100% - get bigger injectors...
    ~Greg Huggins~
    Oct 2013
    Denham Springs, LA
    146
    OR, you're dropping fuel pressure.
    IF you drop pressure, injs will open more to compensate.
    Senior Tuner 10_SS's Avatar
    Mar 2012
    Detroit, MI
    1,320
    I've been wondering about this for awhile..seems like it would be a pretty important table to have access too. Do you know what any of the stock settings are? Just curious.
    2010 Camaro LS3 (E38 ECU - Spark only). MS3X running complete RTT fuel control (wideband).
    Whipple 2.9L, 3.875" Pulley, kit injectors, supplied MSD Boost-A-Pump, stock pump
    LG Motorsports 1 7/8" Headers - No Cats, stock mid pipe with JBA Axle Back
    ZL1 Wheels/Tires
    Tuning Addict
    Jan 2015
    6,813
    .7969ms - it's actually in one of the OS's now thanks to jslic... Still waiting to get added into the rest...
    ~Greg Huggins~
