I have a 2010 Camaro SS L99/A6. Only mods are cat deletes, catback, cold air intake and scoop.
I installed the DSX Tuning Flex Fuel sensor and enabled all the Flex Fuel stuff via HP Tuners.
Problem is, nothing seems to be populated; just a bunch of 0's in the tables.
Can you guys give me some base E85 tune settings to start with?
I have no clue where to start with this.
Right now I have a blend to ease in to the E85 so I can see my fuel pump and injectors duty cycle.
Sensor is showing around 43%-ish ethanol in the tank with 93 pump.
My AEM wide-bands are showing 14.7-ish AFR still, so the PCM is not compensating I suppose.
Thanks in advance.
