Results 1 to 6 of 6
Thread: 6L80E:2-3 shift hit limiter after 5-2 pwr downshift. 2-3 OK on normal WOT upshifts.
    Jul 2011
    25
    I have a G8Gt, 6L80E. TVS1900 at 10 pounds of boost. 3.27 gears.
    My shifts 2-3, 3-4 both hit at about 5900-6000rpm. Limiter is set at about 6400. 1-2 is set for about the same but I can't go WOT in first w/o just spinning but once in 2nd I can go WOT and the 2-3 happens on queue. However, when I am cruising in 5th at 35-40 mph and go WOT, the trans DS 5-4-3-2 and runs up to the 2-3 but goes right past 6000 to 6400. The trans shutters and I see spark drop and TQ delivered drops from 640 to zero then comes back to 500 then drops and comes back and finally shifts to 3rd.
    Why is the 2-3 shift so different between normal WOT run-up vs after a 5-2 power DS? What am I missing?
    My WOT rpm setting is 5200|5200.
    WOT MPH is 48.5|48.5
    normal 94% and 100% throttle are 48.5|48.5
    These were dropped from 5400 rpm and 49.2 mph without seeing any improvement in the 2-3 shift after the power downshift.
    Jun 2011
    Montreal, Canada
    758
    Those multi gear downshifts are killers of 6L80s with high hp. I tune it out and only let it downshift 1 gear.
    2007 Corvette C6 Vert. A6
    LME LS402, Pat G custom cam, ATI 10% OD Damper
    Circle D triple disc 2600, 3.42 Diff
    YSI, 3.0 pulley, ID 1000's
    Alky Control Meth,
    ARH 1 7/8 headers,
    1009 RWHP @ 7000, 817 RWT @ 6000
    Jul 2011
    25
    Quote Originally Posted by realcanuk View Post
    How does one tune out the multi downshift? The 5-2 is the only one that is causing me a lot of grief.
    Jul 2011
    25
    this didn't work.
    Jun 2011
    Montreal, Canada
    758
    Need to post the tune and a log for anyone to really be able to help you.
    Alky Control Meth,
    ARH 1 7/8 headers,
    Jan 2009
    15
    Also interested in how to tune out the multi-gear downshifts. I have a similar problem with my trans with a stock tune. Floor it getting on the highway and it downshifts several gears and hits the rev limiter.
