Let me start at the bottom...Curt, if you know exactly what you want mapped then send him the .xml (edit; just got the xml that you sent him). "He" thinks highly of you and is very thankful for your help. He has also offered you payment which you have told him isn't necessary. So take his money and you and I can work together on this.
Josh, Curt is correct when saying that "He" is pretty stubborn so stock is what it is.
Mike, Thank you for understanding and adding valuable advice. We use a Tazer, bag of ice, and the oxygen enriched fuel makes the cat temps go up too fast, so we are switching to a Sunoco product w/o oxygen enrichment. HP Tuners software is helping him become a better driver. Everyone wants the quick-fast answer and be done. He is in it for the long haul. (another for Mike, HP can write to TCU without the unlock you say?)
I am trying to get him to manual shift after the first 1-2 (since it happens so fast). Then he can hold rpm longer than the (lets just use) CPU commands. Here is a run where everything is over temp and it holds 15 degrees of timing the entire run. If it wasn't for tire spin at the start this would have been a stellar run. Thanks again for everyone willing to help.
Attachment 74346
We all have different dreams. If you can help someone achieve their dream then go for it. If you are too worried about your dream then move on...
Curt, I just noted that HP only allows 24 bits for sampling. So yes! Turning on every channel will kill the information. Not a pro tuner but a left-handed engineer for FCA.
