Results 1 to 4 of 4
Thread: LS9 E85 hot start issues, can someone look at this tune.
    Jun 2007
    7
    Just wondering if someone can look at my tune, I've been having my ZR1 remotely tuned and everything is good except if I try and start it anytime after its been running it usually takes 2 times to get it started cranks for 5-6 sec. then when it starts it stumbles badly for another 5-6 secs. sounds like it running on 4 cylinders, then cleans out. LS9 with 2.6 pulley, snout, CAI, ID1050x injectors, flex fuel kit. I have hp tuners but I haven't done much tuning myself. I've pulled the injectors to make sure they weren't leaking. Thanks.
    Eric ZR1 FlexFuel R17.hpt
    Nov 2021
    4
    I know this is old, but did you ever figure out what the issue was? I?m running similar mods and having a similar issue but only when engine is cold.
    Jan 2014
    Australia
    1,982
    cranking fuel tab the cold start area (far right it uses engine off time) just double the value and blend a couple rows back in and see if it helps, also not too much cranking timing maby 5-10 deg when cold see if it helps, for hot starts just see what it needs as it should fire right up just like petrol
    Nov 2021
    4
    Thanks man.
