Results 1 to 3 of 3
Thread: Actual fuel pressure for a 2001 Camaro V6 3.8L A4
    Apr 2004
    Erie, PA
    464
    Question Actual fuel pressure for a 2001 Camaro V6 3.8L A4
    Hi guys,
    My son and I picked up a 2001 Camaro V6 A4 T-Top SOM car for cheap as my sons first car. Overall the car is in good shape, runs good but runs rough sometimes. Car has about 152,000 miles on it and the engine has about 80,000 miles or so.
    I changed the fuel filter and checked the fuel rail pressure and it's reading about 40psi at idle. If you pull the vac line off the fuel pressure regulator, it jumps up to about 49 PSI. I did other basic maintenance on it as well, plugs, wires, oil change, cleaned MAF, etc...
    What is the idle fuel pressure suppose to be at with these cars?
    Car is 100% stock as they come.
    Thx,
    Bill
    2001 Camaro SS M6 - 23,xxx Miles
    Huron Speed AC Turbo AC Kit - 6.0L 9.4CR, LS3 Heads, 226 232 115 lsa cam, Turbonetics 7575 1.15 AR Turbo
    10.98 @ 133 MPH on 9 lbs boost
    13,565
    Yup, sounds normal to me.
    At idle it should be around 40-45psi, under load it will rise some. The 3800's do not run a ton of fuel pressure compared to like a LS V8 that runs 58psi stock.
    Apr 2004
    Erie, PA
    464
    I was thinking it should be 43 PSI at idle. (3 Bar) My son wants me to tune it, maybe someday!!! lol
