2011 Silverado HD, 6.0, E78 ECM
Without going into details, this truck has never run quite right... hesitation, bucking, etc. I have been reading/learning and scanning for over a year (made some easy transmission changes, etc). Finally I have some time to get this engine sorted out.
I am tuning VVE with fuel trims - yes I will get a wideband and re-tune VVE as well as the MAF, but for now I am going to use the tools I have on hand (I still have a lot of learning to do).
Here are my problems...
1) VVE table uses MAP / Baro. I tried using Math>pressure ratio on the scanner, but I don't get any data. So I used MAP and the same break points but scaled up x100 (for example for .13 on the MAP/Baro I used 13 MAP) assuming BARO is around 100, this should at least get me close. Is there a better solution here ??
2) Despite 9 + attempts at modifying the VVE, My fuel trims seem to get worse. My understanding is that I am supposed to add the values from the histogram (or whatever we call that now) directly to the VVE table, until I get my fuel trims close, then I use "multiply % - half". The more I think about this, the more I confuse myself.... Fuel trims are in percent, but the table displays whole numbers (-1, 5, 11,.... so one). Percents are typically multiplied... So if my fuel trim was -5, I want to adjust my VVE cell down by 5%. If I add to the VVE table, am I adding -5 or adding -.05 (not sure which) neither gets me where I want to go. I did try multiplying and have not seen much improvement. Can someone please explain this a little better for me...?
FWIW, what I am trying to tune out significant bucking felt under load and RPMs 1400 - 2000. when I feel the bucking I can see my STFT go from 10 positive to -10 (ish) and it seems to correspond with the bucking. Taking MAF out of the loop as certainly changed things and the bucking has gotten better and worse with various iterations of my attempt at tuning VVE.
Thanks for all your help!
