Results 1 to 9 of 9
Thread: Bricked my ECM?
    Jun 2017
    14
    Bricked my ECM On the side of the road 2011 Silverado,
    I was being a idiot and unplugged my cable while doing a read on my 2011 LTZ ECM. I'm tuning for a cam. the computer just said service trailer system And stabilitrac. I unplugged the cable and battery and tried to read it, and it failed. I then tried a write calibration, and it asked for my VIN but still failed. The truck doesn't turn over, the dash is stuck with all the lights on. I'm not sure what to do, I'm stuck on the side of the road.
    Try to push in a factory file with a Tech II or MDI.
    Jun 2017
    14
    Quote Originally Posted by jc052685 View Post
    I guess I'll pay to get it towed to the dealer and try that.. I didn't think HP tuners would just brick something like that.. I was reading it not writing.. I'd also think there'd be a way to recover. This sucks lol
    Aug 2017
    Tennessee
    29
    Did you try basic stuff like disconnecting the battery, touching the positive and negative terminals together while disconnected from the battery?
    Key Cycling?
    Push a Factory tune?
    or the Stock tune that was on the ECM..
    Advanced Tuner veee8's Avatar
    Apr 2006
    Raleigh, NC
    449
    Disconnect the battery for 10-20 minutes. That should reset the comms and you can try again. It's pretty hard to brick the E38 ECM's.
    www.crawford-racing.com
    Home of the original and best selling CR-Fueler plug and play port injection controller kits for all GM Gen V direct injection platforms.
    I've had luck with unplugging the connectors from the ECU with my E40.
    Apr 2007
    1,104
    update to the newest version of hpt from your customer page.
    The most hated, make the most power.
    93 Ranger. 5.3 D1X. 1069hp.
    Jun 2017
    14
    Quote Originally Posted by Area47 View Post
    I reset the battery and it didn't help. I then plugged a OBD2 scanner in and surprise surprise I had no communication. What fixed it was I grabbed my stock tune and did a "write all" using HP tuners, and it took like 30 minutes but when it was done the truck fired right up and is back to normal.
    Sep 2017
    10
    Pull your BCM fuse, wait, then put it back and try again.
