Results 1 to 7 of 7
Thread: 3 bar map
    Oct 2013
    228
    3 bar map
    hey , its been years since i have done one , can someone run me through it
    thanks
    jim
    13,571
    What's the application?
    What computer? Keeping MAF (depending on computer)?
    What MAP are you running?
    The skinny is that you'll want to take stock file and apply the 3 bar OS if available then start making your changes to various tables for airflow and fueling. If a newer OS you'd change the VVE tables to support 3 bar.
    Oct 2013
    228
    is a 3 bar map s10 v6 , i just cant remember how to populate the boost section above 105 kpa
    Oct 2013
    228
    Thx
    13,571
    Just continue the VE as it is. Not much to it.
    Slowly ramp up the VE towards 300kpa, use the interpolate or smooth functions to get you a starting point. It may be rich right away but that's where using a AFR/Lambda error will correct it.
    Jul 2007
    12
    hi
    1-copy 105 kpa from 400 rbm to 8000 rbm and past to 315 kpa
    2-multiply 315kpa 3
    3-interpolate between vertical bounds
    i hope this will help you
    Oct 2013
    228
    thanks guys , i just brain farted
