Results 1 to 11 of 11
Thread: Editing DFCO to eliminate decel popping
    Tuner Joe6pt0's Avatar
    Mar 2006
    Indiana
    141
    On a stock cam LS2 with a cat back only (stock cats) what kind of minimal parameter changes should I look at to help eliminate decel popping?
    I'm assuming it’s just easier to turn it off completely if I don't care about fuel economy or larger engine braking-correct?
    Also, when the time comes for headers/no cats how will this change?
    I would think that since the exhaust isn't flowing quite as freely with only a cat back (as it would with headers/no cats), it shouldn't take too much of a change to see results. Maybe I'm mistaken which is why I'm asking
    Mar 2006
    Indiana
    141
    Another question I just thought of.
    Does anyone add fuel to the low kPA values in the VE table to help out also? Or is that more for a cammed/header engine?
    TIA
    Joe,
    Start playing with ramp in and ramp out rates in the blending tables depending on when you're getting the popping. I would start slowing them down little by little and see what effect it has.
    You'll have to let me know how it goes.
    Nov 2005
    Someplace high in the Himalayas
    770
    Just turn DFCO off. For me, it saves no gas because I drive like an idiot all the time.
    www.outlawpontiacdragseries.com
    Come race with us in MA, PA, and VA!
    2005 GTO A4 - Spintech X-pipe with Powerstick mufflers, IAT relocate, Volant, !scoops, !cowlgasket, !skid plate, LM-1, HPT2.0/MPVI Pro USB, 275x40x17 Nitto DR, rolled fenders, Pedders 2985 springs, Britax baby seat with 5 point harness.
    Stock:13.36@104
    Mods in sig:[email protected]
    Jul 2004
    1,579
    Show us a log of when this happens, it may not be DFCO causing the popping. I have modified the DFCO values quite a bit on different vehicles and have yet to experience this as a cause directly from DFCO.
    Nov 2002
    Central Florida
    2,503
    If you don't cut fuel, and have a higher minimum injector
    pulse width than the deceleration airflow can burn, then
    post-combustion becomes more likely (popping). Look at
    the injector pulse width on decel and its relation to the
    dynamic cylinder air value. You would expect a straight
    line relation (within closed loop operating ranges) but it
    may be you are way above the line, when air goes to
    roughly zero.
    Mar 2006
    Indiana
    141
    Quote Originally Posted by shizon
    Joe,
    Thanks for the info Shaun, but we don't have any blending tables in the LS2. At least not available yet to us to modify. I did open an LS1 file to see what you are referring to. So you are assuming it is more spark related?
    All we have available currently for spark is entry and exit spark vs rpm.
    I do just have my DFCO turned off but I still get some minor popping on decel. Its not terrible now but I know when I go headers/off road pipes it will be worse.
    Id like to see some more information on the DFCO and see some examples... i experimented with it and tried to make it aggressive and over did it and it caused driveability issues out the ass, so I turned it back off til I can obtain more information.
    Owner/Tuner Street Performance Syndicate
    06 GTO: D1SC , Full Suspension, 23X .6xx lift Ed Curtis Cam, Mast Heads, Gforce 9" 4.11 Gears, Holley High Rise, Stage 12 Fuel System, Boost By Gear
    01 Duramax: Blown Tranny (again) BWs467 Turbo, Head Studs, Exergy Injectors, Lift Pump, Moonshine
    2014 Taurus SHO: (Wife's Car) OR DPs, Tuned, CAI
    2006 TBSS; AWD SLP Catback, K&N CAI, Tuned
    Senior Tuner IDRIVEAG8GT's Avatar
    Aug 2010
    Roswell, N.M.
    1,956
    Quote Originally Posted by posenheimer View Post
    Dead post revisited lol.
    618/618 motor
    906/862 spray
    Tuner in Training 08RED2500HD's Avatar
    Jun 2011
    Miami,FL
    40
    http://www.hptuners.com/forum/showthread.php?t=36230
    This tune of mine has no poping
    Feel free to review
    2008 Silverado 2500HD
    357 rwhp 382 rwtrq tuned by me
    MODs: CAI, cut out, cat delete.
    (New Mods: Ported TB, pacesetter Long tubes, and off road Y= redynoing soon )
    Aug 2006
    5BA8
    3,253
    Easiest way is just set the entry and exit spark to something like 15 or so. Will take 90% of the popping out. DFCO will still work, just won't pop.
    EFI specialist
    email=[email protected]
