Results 1 to 3 of 3
Thread: boost enrichment question
    Jun 2017
    16
    the pcm uses the richer of the boost enrichment table and the pe table correct?
    or is it used in addition to the pe table?
    thanks
    Dec 2008
    Nevada
    4,452
    its used in addition too
    when the tps and map threshold for PE is exceeded the fueling in PE takes over.
    When the BE map threshold is exceed then BE is the sole Enrichment factor.
    Therefore if you floor it and say a wg sticks making it so your BE map threshold never gets exceeded, then you will stay in PE mode.
    BE does NOT add to PE, they are separate.
    Jan 2021
    26
    I know this is old but it is a question that I have.. I just Need one clarification; When the BE map threshold is reached does the TPS matter? Will I go into boost enrichment at The set map threshold even though the TPS is below the PE enabled threshold?
