I recently swapped out my stock 5.3L for a 408 LQ4. I also swapped out my stock LS1 intake manifold to a Holley Hi Ram. Everything else is the same as last year when the car was running perfect. The car is running speed density.
Now when I start the car it will run for 5-10 seconds and then go into limp mode. It is DBW so I have no throttle control and a high idle at that point.
Here are the codes it throws:
0x10: P0102 - Mass or Volume Air Flow A Circuit Low (Current)
0x10: P0103 - Mass or Volume Air Flow A Circuit High (Current)
0x10: P0120 - Throttle/Pedal Position Sensor A Circuit (Pending, Current)
0x10: P0220 - Throttle/Pedal Position Sensor/Switch B Circuit (Pending, Current)
0x10: P1514 (Pending, Current, History)
0x10: P1516 (Pending, Current, History)
0x10: P1518 (Pending, Current, History)
Some other things I have noticed:
-I am getting 0 TPS voltage in scanner no matter what I do.
-Throttle moves as it should before throwing codes.
-Accelerator pedal position goes to 138% at WOT
-Throttle position (SAE) reaches 99.6% at around 60% throttle
Help!
tune 3 smoothed.hpt
