Results 1 to 4 of 4
Thread: engine over temp enrichment
    Engine over temp enrichment
    Curious to what this table is for, its under the pe options. It states Engine Over Temp EQ Ratio vs. RPM: Equivalence ratio used when engine over temperature protection is enabled. Is this something that should be left alone, does it act as an adder? The tab underneath says fuel mult vs rpm. Just confused because I couldnt find any info on it, and im not sure if something needs done with it or leave it be. Thanks
    1992 z28:Ls3,411 ecm T56, Tick Master cylinder, Monster stage 3 clutch, tsp 229/244 cam, lingenfelter heads, cold air intake, hooker 1 3/4 headers, 3 inch true dual exhaust, ford 9 4.10 gears.
    full Detroitspeed suspension
    bump
    13,572
    Just leave it be, it should only be used by the computer if the vehicle was overheating by an extreme amount. I've never had to change the table.
    Ok, thanks I appreciate it.
