Results 1 to 8 of 8
Thread: E38 - Cooling Fan Desired % vs. ECT - Table Column Axis Edit Possible?
    Jun 2017
    Oxford, OH
    22
    I would like to make the cooling fans come on earlier. Am I missing something? I can't figure out how to change the settings to make the fans come on at say 180 degF. Right now the table column axis starts at 192.2 degF. Thanks in advance for the help.
    Sep 2015
    Santa Rosa, CA
    55
    Look in the sticky section. There is a write up on this topic. Short answer is you can't go lower than the lowest setting in your table without changing your OS.
    Jan 2009
    Spokane, WA
    480
    ...unless you convert to a 2bar or etc custom os
    Jun 2017
    Oxford, OH
    22
    Quote Originally Posted by waynehartwig View Post
    Ok. Thank you both. So I just read that sticky. Just so I'm clear, if I convert to the 2 bar OS upgrade, all I need to do is change my Map Sensor Linear and Map Sensor Offset back to what they are now and then I can control the fans to a lower setting without messing anything else up? Is there any downside to doing this?
    Jun 2017
    Oxford, OH
    22
    Quote Originally Posted by gmtech16450yz View Post
    Very cool indeed, but I don't have the AC on it yet.
    Jun 2017
    Oxford, OH
    22
    Quote Originally Posted by 513Motorsports View Post
    Looks like I also need to populate the VE tables. Those appear to have to be rescaled of course. Anything else that I am missing?
    Here is the updated version.
    Joe's RX8 Rev17.hpt
    Tuning Addict
    Jan 2015
    6,813
    Don't put more than a 15 value in the first temp cell and then of course fix all of the other stuff you mentioned including scaling the VE table for your setup. You might also want to look into pedal for PE and your MAF table unless your spraying meth or something like that.
    ~Greg Huggins~
