I am observing a lean condition 1.5-2 seconds into PE. It is pretty dang consistent. Commanded PE values change between 2500-2700 rpms right after entering PE. I am going to try and kill prediction coefficients and also increase manifold volume by 10% (Increase from factory 13.45L to 14.85L) and see if it goes away? I was wondering if I should try anything different based on others experience with similar issues. I also considered trying to command the same PE values across all RPM breakpoints in PE table to see if the condition goes away, but it looks like its some kind of influence with changing loads and transient conditions? Commanded doesn't match actual? However, if I nail it and move into the constant 11.46 commanded PE RPM cells that commanded matches actual with ~ 2% error.....
V2 CTSV with ported blower, snout, and Mamo ported LS7 TB
ID1000 injectors
All the cooling mods
2.38 pulley making ~ 14.5 psi boost.
Curious to here what others thoughts are? I will report back if the increased manifold volume and killing the prediction coefficients helps out any...
